Finishing Services
Electroless Nickel Plating
n/a
Smooth, glossy finish
Can be applied with
Alodine
Electroless nickel plating (ENP of NiP) is a reaction that deposits a nickel-phosphorus alloy onto the surface of a metal. It uses a purely chemical reaction to induce plating and does not leverage electricity. Though this process takes much longer than electroplating, advantages are a more uniform thickness over even the most complex surfaces (due to not having to rely on varying electric fields), as well as superior wear and corrosion resistance. The standard specification for ENP in North America is MIL-C-26074E, with various grades specifying thicknesses from 0.0003-0.002”.
Design considerations
Our standard offering for ENP adds thickness between 0.0003”-0.0005”, although we can achieve 0.00005” up to 0.002″ if specified in a drawing.
Producing Show-Quality Mockups for CES 2025: Top Manufacturing Processes to Elevate Your Prototypes
The Consumer Electronics Show (CES) is the ultimate stage to showcase innovative technology and futuristic designs. High-quality mockups are essential to captivate an audience and stand out in the crowded exhibition halls. Whether you’re unveiling groundbreaking consumer tech or sleek new designs, the manufacturing process you choose for your prototypes can make or break your […]
Medical Device Manufacturer Uses Fictiv to Clear 18-month Backlog in 4 Months
